Noise coming from back end..
Old Feb 11, 2014 | 05:23 PM
KyungMin's Avatar
Default Noise coming from back end..
I'm getting some diff whine.. but I started getting a "vibrating noise" from the back end of my car.. the "Vibrating noise" goes with the speed of the car so if I'm going 60 and put it in neutral the noise is still there and the noise is faster the if I go faster.... can't figure out what it is.. Had it looked at two places and its not the brakes and they don't think it's the wheel bearing either.. any ideas? One mechanic said it could be something to do with the diff. but he can't figure it out.
Old Feb 11, 2014 | 05:34 PM
S2kPowa's Avatar
Had similar noise was whining, when it rained it was even worse, changed my bearing diff, drive-shaft etc, nothing fixed it, then later i found what it was my axle rubbing against wheel hub.
Hope this helps. and hope its not your diff
Old Feb 11, 2014 | 05:49 PM
KyungMin's Avatar
Axle rubbing against the wheel hub? doesn't the axle go into the wheel hub?
Old Feb 11, 2014 | 06:40 PM
DeeKay's Avatar
If something is that bad within the diff there will be metal debris in fluid. Check fluid for metal flakes.
Old Feb 11, 2014 | 08:21 PM
Murphg05's Avatar
You can also try raising up the back end and rotating the tires to see if you can pinpoint exactly where the sound is coming from.
Old Feb 12, 2014 | 06:13 AM
KyungMin's Avatar
Tried spinning tires.. No luck.. Will check diff fluid
Anyone know where u get amsoil locally in seattle area? Or anything comparable.
Old Feb 12, 2014 | 07:46 AM
AZfury's Avatar
or try driving the vehicle in the air on a lift and listening
Old Feb 12, 2014 | 01:09 PM
S2kPowa's Avatar
Not the part that was going inside bearing the part where speed sensor mounts to that big part was touchibg wheel hub
Old Feb 12, 2014 | 02:26 PM
DeeKay's Avatar
synthetic gear oil works.
turning by hand wont work, lifting rear (using jackstands) level ground, set cruse control at highway speeds and with stethescope you can pinpoint whether its inner or outer pinion bearing, or carrier bearings, or axle bearings. like i said if its that bad there will be metal in fluid which can possibly damage the races of the other bearings aforementioned. sometimes the best option depending on diagnosis and love is to replace all bearings while closely inspecting the ring and pinion. the clutches need to be cleaned as well.
http://www.tooltopia.com/lisle-52500.aspx
$15
Old Feb 13, 2014 | 04:13 PM
KyungMin's Avatar
I think my tires had uneven wear on them.. I had a similar noise come from my prelude a couple years ago and I changed all the bushings with no luck and they sound went away when I got new tires... maybe it's the tires.. it certainly sounds like tires at least.. Getting my diff fluid changed.. will look for shavings.. my friend told me to get an alignment and balance the tires.. :/
Edit: Les schwab said it was a wheel bearing...
polar2k
Jul 15, 2014 08:20 PM
TrumpetTitan
Oct 3, 2011 01:12 PM
s2kbenztech
Tampa
Sep 22, 2009 01:54 PM
Euroflavor
Mar 30, 2009 10:39 AM
krnboi4370
Dec 10, 2007 01:54 PM
