Window Stuck Down
Old Jan 15, 2010 | 05:14 AM
darkin.1's Avatar
Default Window Stuck Down
I have done searches and all i found is people with the passenger switch lock on.
The other day my drivers side window stopped working, Believe need a new motor. However it is stuck about a inch down. Is there anyway of manually putting the window back to the top?
Old Jan 15, 2010 | 05:19 AM
lovegroova's Avatar
Have you had battery problems?
Try putting the drivers side window up using the "bit at a time" part of the switch rather than the "all at once" move. This sometimes fixes things.
Old Jan 15, 2010 | 05:33 AM
eho's Avatar
eho
If that dont work, then you just have to leave it be, happened to my old car once but I force it too much trying to close the window. The glass shattered and ended up buying new window along with the motor
Old Jan 15, 2010 | 05:34 AM
tiger289's Avatar
It could be the switch try taking out the passenger switch and using it to see if it works.
Old Jan 15, 2010 | 05:38 AM
Nick Graves's Avatar
I think there's a reprogramming routine so it can re-learn where is 'top' & 'bottom'.
Old Jan 15, 2010 | 05:39 AM
defiant's Avatar
This happened on pone of my old volvos...AA man came out and took the door card off, hit the motor with a heavy screwdriver...it worked straight away...worth a go?
Old Jan 15, 2010 | 05:40 AM
darkin.1's Avatar
Well heres the thing, My battery died one day so i got another (needed one anyway) next day battery was dead again. Nothing seemed to be draining the battery. However When i lock my car normally the windows auto go up so i assumed it was trying to constantly push the window up (therefore draining the battery)
To test i unplugged the windows from under the door panel and have had no problems since.
Old Jan 15, 2010 | 06:03 AM
MB's Avatar
MB
Member
Dammit I thought his was a window switch thread
Old Jan 15, 2010 | 06:10 AM
Roadkill's Avatar
Are you sure it's down and not just sparklingly clean?
Old Jan 15, 2010 | 06:20 AM
MUG3N's Avatar
I have a spare switch if it is that let me know
