Windscreen washer pump
As title has stopped working, does the pump have a fuse if so where, wiper are fine and plenty of water in tank but cant here the motor for the pump, not the greatest time for no washers, any ideas!! thanks all
there is a pump just inside the drivers side wheel arch, you need to remove the wheel - then take out the liner, the pump is tiny about the size of a D battery... remove it has 2 pipes connected and an 12v power suppply / switch, remove it and test by putting power directly to it - if its stopped working they are around
DBt85
Nov 9, 2016 04:23 AM
Wobbly
Jan 17, 2016 01:12 PM
