Wishbones and geometry question
Old Dec 9, 2009 | 01:28 AM
Gaspode's Avatar
The S is highly adjustable.
It's not your £40 Kwik Fit type adjustment. If the price is really low - then they are not adjusting everything that is needed.
This may help you. Tell them to make the numbers exactly the same as below
Old Dec 9, 2009 | 01:41 AM
Richard_the_Rogue's Avatar
Thanks guys, that's exactly it!
I've found a local place that can do it too
Old Dec 9, 2009 | 06:33 AM
pedrobaby77's Avatar
Are the settings on that sheet ok to use on any year of s2000? I will need to get this done also but i have a 2007 s2000.
If i cant use that does anyone have a newer setup sheet?
cheers guys!
Old Dec 9, 2009 | 06:56 AM
m1bjr's Avatar
Yes, they'll be fine.
Actual setup is a very personal thing, but the above will be good.
Old Dec 9, 2009 | 07:26 AM
Rob88's Avatar
As I was told when I had mine done.
Get a standard setup, then drive it, then you can start asking for things that will change the way it drives.
But you have to start somewhere.
ayellows2k
Jul 1, 2017 07:16 AM
01S2Kevin
Jan 17, 2008 09:27 PM
MaoGuy
Apr 19, 2006 09:11 PM
Black2k3
May 1, 2003 04:06 PM
