Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Helmet help!
Old Oct 17, 2005 | 12:02 PM
IBMcpa's Avatar
I don't see you guys mentioning motorcycle-type helmets - is there that much of a difference? I use my Arai for both motorcycle and auto racing.
Old Oct 17, 2005 | 12:17 PM
patinum's Avatar
From soloracer.com
HELMET RATINGS
SA Rated Helmets:
Snell "SA" (Sports Application) rated professional helmets are designed for auto racing and provide extreme impact resistance and higher fire protection.
M Rated Helmets:
Snell "M" (Motorcycle) rated helmets are designed for motorcycling and other motorsports. They offer slightly less protection than SA rated helmets.
What are the key differences between SA and M Rated Helmets:
SA standard requires flammability test while the M standard does not.
SA standard has rollbar impact test while M standard does not.
SA standard allows narrower visual field than M standard (Some SA helmets aren't street legal).
How do I know if my helmet meets the necessary Snell specifications?
Always check your club rulebook to determine what helmet specifications they require. SCCA Solo rules, for example, will allow you to use the current Snell specification, as well as the previous two Snell specifications. So, for the 2006 season, you could use Snell Snell M95/SA95, Snell M00/SA00, or Snell M05/SA05 helmets. Snell M90/SA90 helmets would not meet requirements after October 1, 2005.
Some other racing organizations will allow you to use the current Snell specification and only the previous Snell specification, so read your rulebook carefully.
Also, be sure that your club will allow the use of Snell "M" rated helmets. SCCA Solo does allow these helmets, although some organizations that run high speed events will require Snell "SA" rated helmets.
Old Oct 17, 2005 | 12:20 PM
patinum's Avatar
I've never had a problem running top up or down. In fact, I thought I read somewhere that top down is preferrable. The idea being that if you flip over, the soft top won't make you safer but instead the soft-top bracing could snap and stab you.
Personally, I prefer top down for this reason, less glass, more visibilty, and more wind=greater sense of speed. Top down driving with a (full face) helmet on doesn't get that annoying until over 100mph which most tracks you might not reach and I would be shocked if you reached that speed for any amount of time in a auto-x.
Old Oct 17, 2005 | 12:25 PM
ToeKneeC's Avatar
guess it's time to retire that M90 open face t00l looking helmet..
my motorcycle helmet is BSI rated .. geesh.. talk about another whole can of worms here..
Old Oct 17, 2005 | 12:35 PM
ruexp67's Avatar
I would prefer top up. You get better aerodynamics and less drag. The top up would help keep your extremities inside the car too.
If you run top down, then make sure you have arm restraints.
Most autoX events don't care if you run top up or down, but most HPDE events do require top up (but not all.)
Old Oct 17, 2005 | 01:41 PM
patinum's Avatar
Dammit Pete. I could have sworn I had read/heard the exact opposite (that they require top down)...although I cannot find anything online confirming either (top up vs down required).
Arm retraits are a good point though.
There would be more drag with the top down, but the few seconds or so isn't worth it to me (under my assumption that top down is safer).
(thinking out loud)
I wonder what creates more drag though...top down, or top up with windows down. I know that windows are required down (glass), but all that wind from the windows would hit the back of the soft top acting like a parachute. On the other hand, top down there may be drag but more area for the wind to escape...I have no scientific basis for this at all
Old Oct 17, 2005 | 02:05 PM
ruexp67's Avatar
It is up to the individual HPDE orginzation, but SpeedTrials and performance driving experience both require top up OR arm restraints.
Old Oct 17, 2005 | 03:21 PM
E-brake's Avatar
Thanks for the help everyone. I'm going to check out North Star later this week.
Hecash-Thanks for the advice but I don't like the idea of buying a potentially damaged helmet. They are only designed to take one impact. A soft hit could create stress cracks that greatly effect the way the helmet would work in a serious impact.
Old Oct 17, 2005 | 04:47 PM
Johnny--2K's Avatar
I've got a helmet that I dont use anymore.....if you are interested let me know and I can get you some pics....it is a motorcycle helmet, but approved none the less. Save yourself some money!!
Old Oct 27, 2005 | 02:38 PM
E-brake's Avatar
I purchased a Bell Sport 3 for a great price from RCS.
Danwolski
Apr 26, 2012 02:06 PM
mickfluff
Mar 22, 2005 01:12 PM
silvershadow
Feb 4, 2004 10:34 AM
BillB
Jul 22, 2003 07:11 PM
integrate
Jan 24, 2002 12:20 PM
