Time for more fabrication!
Originally Posted by pushin9,Jun 9 2007, 04:25 PM
so did you get any numbers?
Also do you have any kind of engine management?
This is very strange to me cause I have not heard of the CTSC kit running lean with the stock pulley at all. Thats why I kinda just put off the engine management till I was gonna run over 7lbs. I've checked the vacum tube from the FMU, no leaks or cracks. Plugs are only 3wks old(NGK 7173's) so they cant be bad, but I'll check just to make sure tomomrrow. Only thing lefted is bad fuel pump, bad FMU or clogged injectors. Whats your thoughts?
Install the $15 fuel pressure meter on your fuel rail to see where your fuel pressure is at. There is a DIY in the under the hood forum.
https://www.s2ki.com/forums/index.php?showtopic=204701
