Check Engine Light came on
Originally Posted by hi-revs,Nov 8 2008, 11:06 PM
mever mind. it was a maintenance required light
hopefully an oil change first thing in the morning will make it go away.
hopefully an oil change first thing in the morning will make it go away.Pretty soon, the maintenance light will be on permanently. You will need to reset the counter to turn it off.
IIRC, with the car off, press both the mph/kmh button and trip meter button at the same time and hold it down while turning the key into the on position. Wait 10 seconds for the maintenance light to flash. That should clear the counter.
Originally Posted by hi-revs,Nov 9 2008, 02:00 AM
^^just curious, should i really cancel the maintenance light on my own?
or should i bring it in or something to get it diagnosed? since i dont know what needs servicing?
just curious, what does IIRC mean?
at about 120k i got this light...reseted on my own and its fine now...did tranny/brake flush and everythin...
In your owner's manual (if you have yours), there is a section on what maintenance is required at different intervals.
On the S2k, all "A" intervals is just a oil change, at the B intervals, there is supposed to be an inspection of the car (annual servicing - Honda wanted 200 bucks for it).
In the B intervals, there is also a number code, like B1 - B6 I believe and for each of those, other things are needed, like flushing the coolant, changing brakes, etc.
You should look it up and see which one you need...
01S2KSA
15
Feb 17, 2011 06:55 PM
