Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
What are the DRLs supposed to be?
Old Nov 1, 2007 | 05:24 PM
idledaylight's Avatar
Default What are the DRLs supposed to be?
I just imported a US S2000 into Canada and had a local (US-side) dealer do the DRLs. I had thought that because they claimed to sell a lot to Canadians, that they would be the ideal place to get the DRLs done. The strange thing is that all they did was make it so my HID main beams turn on as soon as I turn the key. Is that normal? I was under the impression that DRLs were supposed to be your highbeam lights set to half the intensity. Can any Canadian S2000 owners post and describe what their DRLs look like? Thanks!
Old Nov 1, 2007 | 05:55 PM
MR2S2K's Avatar
pretty much DRL are high beans on half, just like you stated, but it is much easier for them to hard wire your highbeams on by your ignition, and then run a relay that cuts when you actually turn on your headlights.
its a bandaid for the DRL fix, but not done correctly.
Old Nov 1, 2007 | 06:05 PM
S2sizzle's Avatar
Your headlights wiill burn out quicker because of the usage if your hid's turns on right away. DRl is the Day time running lights that the US cars dont get. If it's not done correctly you could run into some shitty electrical problems in the long term. Good Luck
Old Nov 2, 2007 | 04:48 AM
swamp's Avatar
go to:
https://www.s2ki.com/forums/index.php?showtopic=192698
The Hamsar module is hard to find but works very well.
Old Nov 2, 2007 | 09:14 AM
Vik2000's Avatar
lol HID turns on when you ignite? Is this why I see bunch of car with HIDs on during the day. I honestly saw no point cuz HID does jack shit during the day. I guess it's purely for the look.
Old Nov 2, 2007 | 10:37 AM
kenny_son's Avatar
haha i have a habit of driving around during the day with my HID's on.
ricer look FTW
Old Nov 2, 2007 | 11:36 AM
MR2S2K's Avatar
usually, higher end cars will run HIDs for day time runners when its dark or cloudy outside. I know a few MB do that. It depends on the make, but European cars are the ones who usually have HIDs on as DLR. But then again they use silly one sided parking lights too ??
Old Nov 2, 2007 | 11:56 AM
Vik2000's Avatar
lol no matter how cloudy it is, i noticed turning on HID doesn't make ANY difference. HID is nothin compared to sun light
Old Nov 3, 2007 | 07:16 PM
kstokes's Avatar
That's incorrectly set up - the installer that did the DRLs in mine did the same thing. It will pass an inspection that way, but it's incorrect.
The correct DRL set-up is by running the highbeams at half brightness. The bulbs are simply run in series so each one receives ~7v (half of charging voltage).
I unplugged the negative side of the relay's magnetic coil on mine, disabling the not-correct DRLs, and I simply turn the headlight switch to the first click (corner markers) whenever it's overcast outside.
Old Nov 4, 2007 | 06:09 AM
swamp's Avatar
You can also go to Canadian Tire for their DLR module, I think it's about $25. Wire it in to your parking lights instead of your headlights. It will pass inspection and be cheaper on bulbs over the long run.
Won't look like OEM but that's a choice.
My 2 cents;
My preference was the high beams at 60% brightness. Small silver car, gray west coast days, wet roads and oncoming traffic. I want to be seen.
TakeshiS2K
Jan 28, 2013 08:17 PM
WPS
May 12, 2004 07:01 AM
tkeedy
Jun 17, 2003 06:43 PM
Stanley
26
Mar 2, 2003 12:02 PM
djl Yellow
Dec 28, 2001 11:35 AM
