Want to Buy Looking for something? Post requests for parts in this forum. WTB Only.
Spoon calipers
Old Mar 16, 2020 | 09:56 AM
Tuned Perfection's Avatar
Default Spoon calipers
Looking for a set of new or used Spoon calipers for the s2000. Message me if you have anything! Thanks!
Old Mar 17, 2020 | 11:34 PM
jackmugen02's Avatar
Former Sponsor
-1 New in box set of Spoon Sports MONOCOQUE CALIPER SET AP1/AP2 45020-MBR-G00 $1,350 shipped with full insurance. I've opened the box and inspected the calipers for damage.Spoon Sports Japan product description: Monocoque caliper set Opposed calipers can be set to have higher rigidity than the stamping type, so they have advantages such as lower drag torque value and no loss of padding. The monocoque caliper has a monoblock structure and a precision mold casting method. The mounting is done by bolts without any processing, and it can be used for front and rear brake distribution and ABS as it is. In addition, the pad used is the same shape and size as S2000 genuine, the rotor size is 300mm, and the rotor thickness is up to 26mm. When installing a monocoque on CL7, DC2 and EK9, a dedicated brake rotor of 300mm t = 26mm is available--- Remarks & special notes: Opposed calipers that have a piston on the outside are also wider than normal calipers, so depending on the mounted wheels, they may interfere with the wheels. In that case, use a spacer to prevent interference, but using a spacer may cause the tire to protrude from the body fender. If the tires protrude from the body, they will not be suitable for vehicle inspection. First of all, please check whether it can be mounted on the wheel used in the shop where you can put it on. If you have any questions, please contact our sales department.
https://www.s2ki.com/forums/member-s...parts-1164435/
vassilis_t
Sep 24, 2017 04:58 PM
Mccormick009
Jul 11, 2017 07:58 PM
noobs2kk
May 29, 2017 01:29 PM
Kiwiflavored
NYC Metro Stock Exchange
Nov 24, 2016 01:59 PM
