16x7 tire options
Old May 15, 2016 | 09:36 PM
heshma's Avatar
Default 16x7 tire options
Just got a 02 ap1 that has aftermarket 16x7 wheels on it. They currently have 205 on all 4. If i plan on putting some track days in, what would be a good choice.
1) keep current rims and go to 225
2) get stock ap1/ap2 rims and do 225/245 setup
Old May 15, 2016 | 09:44 PM
EricJT7's Avatar
Even the stock ap1 wheels would be better than your current setup, they're 7.5" in the rear. AP2 Rims with 215f/245r or 225f/255r would be a much better setup. And 17" wheels look good on the S2000 imo, opening up your tire options as well in the process. A 255/40/17 will pair better than a 245/40/17 with a 225/45/17. With 215/45/17 front, run 245/40/17 rear.
Ap2 OEM size: 215/45/17 fronts, 245/40/17 rears. 7 inch front wheel (+55 offset) front, 8.5 inch rear wheel (+65 offset).
You can run 225/45/17 tires on the AP2 OEM wheels in front, but consider pairing them up with 255/40/17 rears if so for a better match. Otherwise your front tires would have a bigger diameter with the 225/245 pairing for 17" sizing.
Old May 27, 2016 | 08:43 PM
maomaolong's Avatar
Thanks for the detailed information! I just got my 03 AP1 ( no mod at all) with stock wheels and am planning to get some after market wheels. I have a question, if I choose 225/45/17 front and 255/40/17 rear set up, do I need to roll the fender? I don't want to mod the body of my S.
Old May 27, 2016 | 09:51 PM
S_DosMil's Avatar
Stay within the correct offset range and you will have no issues. If you go with OEM AP2 wheels. No need for any rolling. I was running ap2v1s lowered about 2 inches with 225/255 setup and never rubbed.
Old May 28, 2016 | 09:59 AM
clarkster009's Avatar
16x7 tire options = sell and buy wider 17s.
Old May 28, 2016 | 12:50 PM
Manga_Spawn's Avatar
Site Moderator
Option #2 all the way. Get rid of those wheels and tires they are not good for the S.
s2000maniac
Oct 11, 2012 09:50 AM
kolyan2k
Oct 20, 2011 05:15 AM
DiscoWagon
Sep 30, 2010 06:00 AM
stolitonic22
May 16, 2008 10:55 AM
NoRawkus305
Apr 6, 2008 04:50 AM
