17 inch rims....
Old Mar 2, 2009 | 11:53 PM
jonner's Avatar
Default 17 inch rims....
What is the most aggressive offset that the s can run on a 17 inch rim with stock suspension and without and mods needed....??
Old Mar 3, 2009 | 07:25 AM
EBinVA's Avatar
Do you consider rolling your fenders "mods" or not?
Also, it will look really goofy to have an aggressive setup on the stock suspension. There is too much of a gap between the wheel/tire and the fender to pull the look together so it'll have a disconnected and silly look to it.
Old Mar 3, 2009 | 09:51 AM
Euroflavor's Avatar
AP2V1. get COILS!
Old Mar 3, 2009 | 10:12 AM
silentdancer's Avatar
most aggressive i would run on stock susp/ stock body is +50, anything lower will look really weird
Old Mar 3, 2009 | 10:32 AM
ZDan's Avatar
Please consider that if you only go by OFFSETS, the more "agressive" you go, the NARROWER you must go for the exact same "flushness".
That is, many people consider a 17x8 +35mm offset wheel to be "more aggressive" than a 17x9.5 +54mm offset, but they put the outside lip of the wheel at exactly the same place! I don't call the narrower wheel setup "more aggressive"...
See the first post in the stickie for a general guideline of what offsets you can run for a given tire width: https://www.s2ki.com/forums/index.php?showtopic=342793
Here's the pertinent data for ya:
For the front:
205 tires: +43 offset minimum (6.5
Old Mar 3, 2009 | 10:37 PM
jman77v309's Avatar
silentdancer.. your sh-t looks sick brah.. that drop is bananas.. you'd get tickets here for that height here in orlando..
Old Mar 4, 2009 | 01:21 AM
jonner's Avatar
Cheers for the help folks....
Old Mar 4, 2009 | 01:41 AM
Dressed2Kill's Avatar
Carnut12
Apr 9, 2017 10:25 AM
riceball777
Sep 10, 2013 10:28 AM
S2KPUDDYDAD
Dec 20, 2005 04:26 PM
nos_son
Dec 1, 2005 03:02 PM
myflys2k
Aug 12, 2004 12:29 PM
