17x8.5+30 (F) 17x9.5+35 (R) fitment help
Hi guys,
yet another noob question. I've been looking on the forum and getting mixed opinions as to whether or not i need to pull/flare the fenders. I'll provide as much info as i can. At the moment all my guards are fully rolled. Fronts have a very very minor pull maybe 0.5-1cm. Fender lining have been trimmed and bumper tabs have been relocated. I'm currently running 17x8/9 +40 with 225/255 tyres and -2.0 camber in front and -3.0 camber in rear. I have height adjustable coilover and lowered with about a finger gap front and rear (no scrubbing issues).
I've found a nice set of ce28's in 17x8.5 +30 (F) 17x9.5 +35 (R). I know this is fairly aggressive but I want to try and fit these without having to pull/flare the guards (I will eventually when I have enough funds). The ce28's come with 225/255 re-11's. So basically I want to know if these will fit with these tyres without having to pull the fenders. I dont mind if i have to dial in a bit more camber to fit them. I also want to try and keep the finger gap height for looks, otherwise it might just look weird.
Any advice or input would be much appreciated
Thanks
Thanks
Site Moderator
So I currently have 17x9 +43 245/40/17 fronts and 17x10 +35 rears 255/40/17. -1.9 front and -3.1 rear camber however I did flare my fenders with a roller. I think you will have more trouble fitting the fronts than the rears. You camber settings are already good. You may just need to borrow a fender roller and flare out your fenders a little more. Hope that helps.
Site Moderator
To a point. It is risky because the paint can chip or crack but it is doable. I was able to get mine flared enough for the wheels to tuck in. I guess a shop could do it just depends on the shop.
