17x8 front and 18x8.5 Back
Old Apr 25, 2011 | 06:45 AM
it'S2klean's Avatar
Default 17x8 front and 18x8.5 Back
Im looking to buy wheels here off a member but he has 17x8 setup for the front and 18x8.5 for the backs....
This would give the car a kind of haunched look, like its leaning on the front which i really dont mind, but im wondering if it would effect the cars handling at all...
Let me know your opinions and thoughts
Thanks
-Nick
By the way heres a link to the sale.
Front: 17x8 +62 (these both have 15mm spacers that are on them which you can take off and sell +47 with spacers)
Rear: 18x8.5 +58 (one of these has a 7-10mm spacer that you can take off and sell)
Old Apr 25, 2011 | 08:18 AM
PalenkosBro's Avatar
Euro guys call it "rake" .....subscribing
Old Apr 25, 2011 | 08:38 AM
1nate7's Avatar
There won't be much if any difference at all on the handling if you run proper tire sizes (most likely 225/45/17, 255/35/18) that are the same overall diameter. The biggest issue is aethestics. Obviously if you are running the same tire diameter then you are going to have more wheel/less tire sidewall in the rear compared to front. Cars that run staggered wheel diameter stock (Corvette, NSX, etc) almost always run staggered tire diameter also so the tire sidewall is the same front/rear.
Old Apr 26, 2011 | 09:49 AM
GoOn3's Avatar
over all it will effect the steering feel if you run the larger side walls but really nothing more
Old Jul 17, 2011 | 08:20 AM
sanchez's Avatar
I wonder if anybody could help me on the same subject?
Im looking to buy a set of NSX wheels, fitment is front 16'' 7.5 and rear 17'' 8.5
Will this fitment be ok?
I know you say its not un-ordinary for a car to run staggered wheel sizes, especially if i go for the different tyre sizes, then there wont be much difference if any.
So it will still drive fine? No unusual handeling?
Anyone have any pics with them fitted?
Old Jul 17, 2011 | 08:36 AM
SpGish20's Avatar
I currently run Nsx wheels. I have the stock Nsx tire sizes as well. No problems here.
Old Jul 17, 2011 | 08:42 AM
sanchez's Avatar
Thanks man, looks great!!!
Do you happen to have the specs/sizes to the wheels and tires?
Are you running stock suspension? Or was and arch rolling needed?
Old Jul 18, 2011 | 03:19 AM
SpGish20's Avatar
Taken from Nsxprime:
1994 - 2001 Front 16" 7" 16.75 lbs.
1994 - 2001 Rear 17" 8.5" 20.85 lbs
Offset (1991 - 2001) 55 mm front, 60 mm rear
Offset (2002+) 55 mm front, 56 mm rear
Center bore (all years) 70(.1) mm front, 64(.1) mm rear
Bolt pattern (all years) 5-bolt pattern, 114.3 mm bolt circle
Lug nuts (all years) 19 mm with 12 mm x 1.50 thread pitch
Tires. Front 215/45/16 Rear 245/40/17
Im running Eibach Springs, no fender mods needed.
Old Jul 18, 2011 | 04:03 PM
sanchez's Avatar
Thanks alot mate, a great help there
kueda
May 11, 2017 08:35 AM
Fastfour
Apr 27, 2010 01:42 PM
shmolie
Jan 6, 2010 07:02 PM
I dream of S
Mar 7, 2007 11:38 AM
dmw16
Aug 28, 2006 07:40 AM
