17x9 +35 stock fenders?
Old 12-12-2011, 08:35 PM
JNova's Avatar
Default 17x9 +35 stock fenders?
Hey guys,
Wanna see some pics of 17x9 +35 all around on stock rolled
and/or pulled fenders. I'm also planning to run either 245 or 255
All around. Is that possible?
Thanks
Old 12-12-2011, 09:35 PM
jtranizzle's Avatar
I had 17x9 +45 w/255 all around... don't think it's possible to have stock fender work. I had to roll the rear and relocate the tab for the rear. I also had to shave parts of the rear bumper. The front was also slightly pulled.
Perhaps if you had a ridiculous amount of negative camber, but other than that I don't think you can fit 17x9 +35 w/o fender adjustments. Or of course if you are 4x4 status.
Old 12-13-2011, 06:41 AM
ryuken's Avatar
It's possible. Check out this thread. It has lots of pictures for reference. https://www.s2ki.com/s2000/topic/846...rey-pearl-ap1/
Old 12-13-2011, 07:33 AM
Banned
vividracing.com's Avatar
Ride height and alignment are a big factor here. How low are you? How low do you plan to go? Are you willing to run an aggressive alignment?
Old 12-13-2011, 07:37 AM
FuknS2K's Avatar
Originally Posted by ryuken
It's possible. Check out this thread. It has lots of pictures for reference. https://www.s2ki.com/...grey-pearl-ap1/
in the above therad he states:
"hired someone to do the bodywork on her (sand and prep, fix dents, fill some holes, flare front and rear fenders)"
bolded emphasis mine. just FYI.
i have 17x9 +45's and lowered to 1 finger gap on all 4 corners. you need fender work period or just enjoy the 4x4 look.
Old 12-13-2011, 08:46 PM
05APdeuce's Avatar
I run 17x9x4 with a +42 offset in front and +35 in the rear with 255 tires on all 4 corners. -4 camber rear and -1.8 front fenders rolled, bumper bolt moved and bumper trimmed. No pull and no flare I have very minor rubbing in the front. none at all in the rear.
Old 12-14-2011, 02:06 AM
TTMartin's Avatar
How stiff are your springs?
Old 12-14-2011, 06:12 AM
05APdeuce's Avatar
not that stiff at all. I run megan ez streets which are 10k all the way around
Old 12-14-2011, 01:27 PM
howang's Avatar
17x9 +35 245/45 all around
rolled and pulled just a bit. no rubbing at all but im not slammed. 1.5 finger gap all around
Old 12-14-2011, 01:51 PM
Mar48's Avatar
you guys he said rolled or pulled is fine just that he wants to keep stock fenders... it will definitely work with a pull, just search for images in the gallery.
Quick Reply: 17x9 +35 stock fenders?
