17x9 too wide?
Old Oct 7, 2004 | 02:18 PM
Ferrell's Avatar
Default 17x9 too wide?
F - 17x8 35mm offset
R - 17x9 38mm offset
Will I have any problems, lowered on Buddy Club coilovers?
Also, what size tires are recommended?
Thanks!
Justin
Old Oct 7, 2004 | 03:05 PM
turbo_pwr's Avatar
Any problems? Not if you don't consider blowing out your tires and fenders a problem. That won't fit at all front or back. You need probably at least a +55 offset for an 8" front and close to a +65 offset for a 9" rear.
Old Oct 7, 2004 | 05:21 PM
Ludedude's Avatar
Administrator
Old Oct 7, 2004 | 09:43 PM
topcat7111's Avatar
Actually 17x9 you could run 55 offset and up, 63 prefer. I got 18x9.5 with 62 offset in the back. Running Tein Stech springs with 1" drop. I could get 1 and 1/2 fingers in between top of tire and wheel wall. And i have no issue with the back rubbing, even at high speed!!
Old Oct 7, 2004 | 10:02 PM
Nobody's Avatar
You can fit 17x8 and 17x9 but not with those offsets. The Shuk FR1? offsets are perfect for 225/45 and 25540 tires.
Old Oct 7, 2004 | 10:13 PM
shaolin's Avatar
i have 17 by 9 all around with + 65 off all around. i don't rub.
tire size i use is 255 40 17 PS2 all around. even complete u turn have no problem
Old Oct 8, 2004 | 08:03 AM
Ferrell's Avatar
Thanks!
Justin
Thanks guys
....oh how I wanted those Regamasters
Old Oct 8, 2004 | 09:48 AM
turbo_pwr's Avatar
For those rims you might be able to pull off the 17x7 +45 front and 17x8 +45 rear if you roll your rear fenders.
MickeyS
Apr 14, 2010 02:46 PM
1yamil
Jul 21, 2009 06:53 PM
Mik3
Jul 27, 2006 09:04 AM
boredfast
Feb 20, 2006 06:37 AM
sebmour
Oct 11, 2005 02:28 PM
