Advan RZ
Old Jan 25, 2009 | 02:17 PM
blueap2's Avatar
Default Advan RZ
I was wondering if I would need any modification to run advan rz
Front: 17 x 7.5 +48mm offset
Rear: 17 x 8.5 +51mm offset
I plan to use 225/45 and 255/40 tires
I am also dropped about 2 inches on skunk 2 springs...thanks!
Old Jan 26, 2009 | 07:49 AM
SpooN-FED's Avatar
I think you will be fine in the fronts, but the rear's you might need to roll. It also depends on what tires and camber settings you run. Some tires come with bigger side walls.
Old Jan 26, 2009 | 07:52 AM
s2k dre's Avatar
rears should fit with a 255 tire. The wheel is only 14mm more agressive than stock! The front fits easy.
Old Jan 26, 2009 | 08:02 AM
blueap2's Avatar
thats what i figured about the rear...anyone running these wheels?
Old Jan 27, 2009 | 07:02 PM
GranPrix's Avatar
Same exact sizes I plan to go with.
Old Jan 27, 2009 | 07:57 PM
track309's Avatar
[quote name='blueap2' date='Jan 25 2009, 05:17 PM']I was wondering if I would need any modification to run advan rz
Rear:
Old Jan 28, 2009 | 07:15 AM
GranPrix's Avatar
Originally Posted by track309' date='Jan 27 2009, 11:57 PM
Atleast go with 45mm offset in the rear to get the GTR face, concave face. Here's mine
You rolled on the rears though right?
RylisPro
Sep 22, 2010 04:41 AM
shadowz64
Sep 8, 2010 09:24 PM
JT-KGY
Apr 13, 2004 01:12 PM
mcs2000si
Dec 23, 2003 11:50 AM
OPTION
Jan 20, 2003 10:07 AM
