Need some recommendations for proper offset
Old Apr 12, 2004 | 12:39 PM
JT-KGY's Avatar
Default Need some recommendations for proper offset
looking to get 18x8.5 for the fronts and 18x10 for the rears.
18x8.5, offsets offered: 47, 54, 63
18x10, offsets offered: 50, 55
also.. anyone know what "low disk" "high disk" "super-high disk" mean? i.e. "Low Disk 18x10"
planning to run 245/40's in the front and 295/35's in the rear.. tirerack carries both the tires i want so that part is covered...
Old Apr 12, 2004 | 12:46 PM
S2000_Europe's Avatar
PM EDIT cjb80 EDIT, or check www.chrisdrivesafastcar.com
He was runnig 285 on the rear
Old Apr 13, 2004 | 08:51 AM
Tireguy's Avatar
[QUOTE]Originally posted by JT-KGY
Old Apr 13, 2004 | 01:12 PM
JT-KGY's Avatar
i think i spoke with you before at california speedway..
i drive the yellow s2k in asp..
i'm currently running 17x7.5 front / 17x9 rear..
tires: hoosier's AS03's (now AS04's) 225/45/17 f - 275/40/17 rear
hoosiers run much wider than street tires..
bmw's run 245's on 8.5" wheels.. like the technoviolet m3 you might have seen next to us.
245's is pretty much the ideal size for 8.5" wheels.. 295 will fit on 10" wheels nicely without problems (keep in mind, i said on the wheels, on the car remains to be seen).
i'm mainly concerned with offset.. we might flare the fenders if needed.. it will help with the hoosier's as well since they barely clear with rolled lips..
butdamnbrian
Mar 4, 2014 08:44 PM
blueap2
Jan 28, 2009 07:15 AM
mwilly00
Feb 10, 2007 09:09 AM
9kFever
Jan 13, 2005 08:46 AM
mcs2000si
Dec 23, 2003 11:50 AM
