Alignment and noob questions!
First of all sorry if I suck when it's come to cars.
Just ordered those enkei rpf1 mag with Hankook rs3 tire and I was wondering if any of you bought the same or similar setup and what did you do to make them fit with a 1" drop or what ever your drop is.
Or if you have any suggestion for the drop I'm open but I can't really got higher then 1" in the front,cause of the road where I live.
I know I got to roll my fender and relocate the tabs but when it's come to the alignment I really don't know what spec I need to keep a good street/track setup.
Like: Camber
Caster
Toe
I ask all those question because my mechanician isn't super good with those tire/mag set up so I want to be sure of getting a right alignment for my needs(streetAkabigholesmountain)And I'll start doing track this summer.
All your suggestions are welcome!
Like: Camber
Caster
Toe
Ok seriously this is thread #3 from on about this same setup. You have been told what you need to do to fit these. The only new question is the alignment part and you could have asked that in one of the other threads.
If you are only drop an inch and you roll fenders and relo the tabs you should be able to do the UK alignment and since I know you won't search for that and will just ask what are the UK alignment specs here they are.
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0
rear toe 0.20 total 0.40
Now please stop making new threads to ask the same questions.
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0
