Alignment Suggestions
In a day or two, I will have had all the parts i've purchased installed. I'd like anyone with alingment expertice to suggest some numbers for Caster, Camber, Toe.
Here are the factors to consider.
Engine:
Fujita Intake
Tires:
Sumitomo HTRZ III 215/45/17f and 255/40/17r
Suspension:
Tanabe Sustec sway bars 30.4mm front and rear
Buddy Club Race Spec Damper kit with upper pillow ball mounts 10kg/560lbs spring rate front and rear.
The car will most likely be lowered from 1 to 1.5inch front and rear.
With these variables, what would one suggest be good alingment numbers. It will mostly be a touge car. Will not see much track time if any at all. The car is also NOT a daily driver. Weekend car only. And I do not take long trips with the car.
Any suggestions and or questions are more than welcome.
Engine:
Fujita Intake
Tires:
Suspension:
BerlinaBayRidah
Apr 9, 2006 12:27 AM
