Amuse wheel offset question?
Old Apr 16, 2004 | 09:02 AM
hatchimon's Avatar
Default Amuse wheel offset question?
Does anyone know here what offset the amuse s2k is running? I know they use ce28n in the 17x9 trim but are they all the same offset or is the fronts running a smaller one then the back? If anyone has the answer or if this is in the wrong forum please let me know. Thank you ahead of time.
Old Apr 16, 2004 | 09:39 AM
fuse's Avatar
They are supposed to be 63mm offset all the way around. I think it takes some work to get the front to not rub on the inside.
Old Apr 16, 2004 | 09:59 AM
S2kRob's Avatar
I would like to know this as well.
I believe the tire setup they run is 255/40-17 front and rear. Also, the car has modified front and rear fenders to fit everything underneath it.
But it is supposed to be fantastic to drive.
Old Apr 16, 2004 | 10:28 PM
fuse's Avatar
I've tried 245x45-16 A032 on 16x8 50mm offset from my RX7. It has a really different feel. The rear is a little loose, but very predictable. I have not tested it on track, but feel nice and predictable in the canyons. To make it work right, a lot of work has to be done to make it work well on track. My RX7 wheels aren't the offset I'd like. I'd spend the time to figure it out if I found a good set of wheels that are 17x8 45mm and 17x8 55mm offset.
Old Apr 16, 2004 | 10:30 PM
xviper's Avatar
Moving this to the "wheel/tire" forum.
amusepanda
Nov 27, 2008 07:10 PM
2nds2k
May 16, 2007 09:44 AM
2HOTS2k
Nov 30, 2005 05:13 PM
Dark_Sub_Rosa
Dec 11, 2003 01:48 PM
samlee888.com
Sep 4, 2002 03:43 AM
