Offset question
Old May 15, 2007 | 09:12 PM
2nds2k's Avatar
Default Offset question
Does offset affect the handling dynamics ? For example if I were to run a +22 front and +54 rear will that handle differently as opposed from a +40/54?
Also assuming that the rim sizes remained the same. Any help would be appreciated. Thanks
Old May 16, 2007 | 06:04 AM
CaptainMike's Avatar
Technically yes. Not enough that you would notice in the real world
You can't fit a +22 up fron BTW (without a widebody)
Old May 16, 2007 | 09:44 AM
Jim@tirerack's Avatar
Former Sponsor
A wider track or lower offset will improve handling. But it does reduce wheel well space and on the S2K can cause rubbing. Like CaptainMike stated without major modification to the car a 22mm offset won't come close to fitting.
dmw16
Apr 5, 2007 12:29 PM
2HOTS2k
Nov 30, 2005 05:13 PM
Type R / Si
Oct 14, 2005 12:21 PM
hatch4raceb16
May 21, 2005 03:22 PM
Dark_Sub_Rosa
Dec 11, 2003 01:48 PM
