Ap2 stock size wheels and tires. Educate me properly
Old 02-05-2017, 07:41 PM
  #31
Site Moderator
Manga_Spawn's Avatar
Originally Posted by rrounds
If you call a C/R front s/b a modified suspension, well I guess I also modified my car because I don't run stock 16 year old tires.
My point is you don't have to be limited to 215/225 front and 245/255 rear in a 45/40 series unless your lowered. I load my S down with 480 lbs. when we travel and I have not rubbed anywhere.
ROD
Of coarse it is modifying your car if you put a different sway bar in. Even if it is an OEM sway bar from a different model. You still changed suspension components out. A sway bar is not a wear item tires are and comparing them is completely irrelevant. The title of the thread is "AP2 stock size wheels and tires" not "what other size options do people run on AP2 wheels." The OEM AP2 sizes are 215/45/17 and 245/40/17 (255/40/17 on the CR). As Junky said if your tires work for your application then great! That however was not the question nor are they a common plus size option like the 225/255 others provided.
Old 02-06-2017, 03:18 AM
  #32
Chuck S's Avatar
Received 1,138 Likes on 1,001 Posts
I started running "CR-spec" 215x45/255x40 tires on my 2006 street car last summer. OEM suspension. No issues noted. These are on Einke wheels, of course, that Honda put on the car at the factory.
-- Chuck
Old 02-07-2017, 11:44 AM
  #33
rrounds's Avatar
He also says "Educate me" if everyone says just run the stock size summer tire, we don't need this forum or any forum. Just read your owner's manual and call it a day.
ROD
Old 02-07-2017, 01:27 PM
  #34
Site Moderator
ROD
Funny we clearly do since the question was still asked despite the info being available in a sticky at the top of this forum.
Old 12-12-2021, 11:52 AM
  #35
S2KIBear's Avatar
-- Chuck
I’m currently running Michelin PS4S stock size on AP2 V2 wheels. I’m looking at getting some AP2 V3 wheels. For spirited street use, would you recommend just swaping the tires over or maybe get some new Michelins in 225 front / 255 rear?
Old 12-12-2021, 03:35 PM
  #36
TsukubaCody's Avatar
If you have good tires 215/245 is plenty. 225/255 is basically all placebo for street driving.
Old 12-13-2021, 03:39 AM
  #37
Chuck S's Avatar
Placebo but those 255s look good from the rear! Surprising the difference the additional not-quite 1/2" width makes -- or maybe that's seeing what I want to see?
AP2V2 wheels are "proper" for a 2007 but I've always wanted to at least try AP2V3 wheels for the cosmetic update. Haven't seen them on the market in a couple of years though.
-- Chuck
Old 12-16-2021, 03:56 PM
  #38
Live Fast's Avatar
I mean it's a sticky for a reason.
I currently have the placebo 225/255 stagger for my Conti ECS since the 215/245 looked slightly stretched on it and now it has the look I prefer for my daily tires.
powerpunk5000
01-20-2015 03:38 PM
juno1996
01-06-2015 08:24 PM
sho-one
09-15-2008 08:31 PM
tntrac
08-21-2008 11:27 PM
bigboost17
09-03-2007 07:00 PM
Quick Reply: Ap2 stock size wheels and tires. Educate me properly
