Axis Reverb fitment
Old Apr 21, 2005 | 06:51 AM
compmonkey1's Avatar
Default Axis Reverb fitment
Axis recommends runing 18 x 8.5F +45 and 9.5R +55. I've known the owner of Axis for a long time and trust that he knows what he's doing. But, if my calculation is correct, this offset will add an extra 35mm from the stock wheel's face to the fender lip in both the front and rear. Does this seem a bit aggressive to anyone? Will this set up rub? Thanks in advance.
Old Apr 21, 2005 | 06:57 AM
esracer's Avatar
I think you should be fine with those offsets
Old Apr 21, 2005 | 08:28 AM
l8brakr's Avatar
Stock height you might be ok but will most likely rub during hard cornering and bumps. I'd try to stay on the shorter side of tire sizes and a more aggressive alignment would help too.
Old Apr 21, 2005 | 08:41 AM
Thanks for the input.
I plan on running a koni yellow with eibach combo. Is there a recommended tire size so that I can avoid rubbing as much as possible?
Old Apr 21, 2005 | 09:10 AM
esracer's Avatar
well I know of someone on the board who is running 17x7.5 and 17x8.5 with 43 up front and 48 in the back and he is also lowered on eibach's and he has no rub, he's running 225's up front and 245's in back.
Old Apr 21, 2005 | 11:45 AM
04RioS2k's Avatar
search option is your friend....but since this is your first day here I did it for you....
https://www.s2ki.com/forums/index.php?showt...&hl=axis+reverb
as you can see the back sticks out alot.......
Old Apr 21, 2005 | 11:52 AM
Thanks everyone for the help. i'm probably going with their 18x7.5 +42, 18x8.5 +45. It'll save me 3mm on the rear and I'll probably be ok with 245/35 falken GRBs.
Iblufftomuch
Jun 4, 2013 01:34 PM
114_ap2
Feb 21, 2008 01:47 PM
Tuanster
Jun 6, 2007 06:18 PM
C-IS
Jul 27, 2005 09:42 AM
B SweepeR B6
Apr 1, 2005 06:56 PM
