BLITZ BRW 18x8 +45 offset tire size?
Hi,
I'm willing to swap stock wheels on my MY08 Platinum White S... The ones I'd like to use are BLITZ BRW 18x8 +45 offset in graphite gray. Like on this picture:
http://www.aspecproducts.com/forums/evom/b...818x9+35BMB.jpg
I have a question... What tire sizes should I use? I've calculated and they seems to be 225/40/18 on the front and 245/40/18 on the rear. Please confirm. Or not
Thank you!
Anton
Thank you!
Anton
Originally Posted by Jim@tirerack,May 14 2010, 03:56 PM
The rear would actually be a 245/35R18 not a 40 Series.
It depends if you're lowered or not. On my Blitz Type 01s, my specs for the front were 18x8 +48 on 225/40/18 tires and I rubbed on big dips. I switched to 215/40/18 and no longer had any rubbing issues. Your rears should be fine. If you put 215 in the front, it may look a little odd because the fronts will have a slightly stretched tire and the rear will look meaty.
OK, I'll bump my own thread. I've checked fitment guide here and it tells +45 offset with these sizes (215/40/18 and 245/35/18) should be fine. But it DOES rub the fenders with the most negative camber. Both front and rear. So DON'T DO IT. Probably even +48 offset should be fine but BLITZ does not produce BRW with anything higher then +45. To avoid rubbing I've installed spacers between shocks and body and it had solved the issue but DON'T DO IT AS WELL. Another thread to tell why...
Austin_S2000
Apr 16, 2001 10:04 AM
