Can scalloped tires cause unbalance?
I'm tried to balance my rear wheels twice and was told by the first shop the rears were out of round. I didn't really consider this an issue until I noticed a vibration above 75mph. I decided to take it to another place to try and balance the rears again, they balanced it without saying anything so I assumed its all good. However, the vibration is still there if not worse.
I did notice the tread wear is cupped/scalloped, can this be the cause of the imbalance? I hope the rim isn't bent because there are zero signs of visible damage.
Originally Posted by mister x,Jul 31 2009, 06:09 PM
IIRC badly cupped tires can oscillate at certain speeds resulting in vibration.
If something was out of balance, you'd feel it all the time, not just under high speeds. It seems to me that you and I (also have the same problem) have the classic symptoms of CV pitting. Our cars rear axles are notoriously known for the CV's to get pitted on the inside and cause a vibration that is present either under acceleration or high speeds.
Is option 2 worth it?
Read up here -> https://www.s2ki.com/forums/index.php?showt...&#entry10548518
**T1R 2-piece half-shaft spacers are my next purchase.
Originally Posted by negcamber
You have 2 reasonably priced options:
- 1) Swap the CV buckets from driver's to passenger side and vice-versa. This costs time and requires some mechanical skill (if you installed your own coil overs you can probably tackle it).
- 2) Install 2-piece half shaft spacers. They'll cost $150-200 There are also 1-piece spacers that are cheaper, but they take nearly as much time to install as it would to swap the CV buckets...and that is free.
As far as an unbalanced wheel, a slight imbalance is only noticeable at high speeds so its not necessarily all the time.
An interesting thing I noticed today was how my car behaved with this new wheel/tire combo. The RPF1s are fine but I have Kumho Mx on front and Cooper Zeon in the back. When I'm driving 60mph I jerked my steering wheel from left to right and the car just doesn't feel planted, it would settle and wobble slightly. When I did this with my OEM wheels and Fuzion ZRis all around, the car felt completely planted and stable.
This issue is baffling me so I just bought a full set of Hankook Ventus V12 Evos, its a bargain for the performance (C&D did a test in July and ranked these 2nd out of a line up of ) and there is a $50 off coupon. I'll let you guys know if this issue is resolved once I get the Hankooks mounted.
50cent
11-29-2003 11:03 AM
Gernby
09-15-2003 07:07 AM
