Check your wrench!
Old Jul 29, 2008 | 08:54 PM
supahman04's Avatar
Default Check your wrench!
So not that important unless your in an emergency but the lugnut wrench that came with the car in the tool kit in the trunk is a 19mm. My lugs are 21.
So unless you wanna be stuck, check yours just in case.
Old Jul 29, 2008 | 08:58 PM
AP2's Avatar
AP2
your lugs are probably wrong....most honda come with 19mm head lugs, the only honda i know that rocks a different size lug is the newer odyssey.
Old Jul 29, 2008 | 09:03 PM
supahman04's Avatar
Your absolutely right. I worked all last year at discount tire and all honda's are 19 mm except the oddesy. And one pilot, but i dont think his lugs were stock. But my lugs look as stock as can be. Fit perfectly.
I didnt understand it either. Just making sure ppl dont get stranded.
Old Jul 29, 2008 | 11:23 PM
AP2's Avatar
AP2
i work there too...the only other lug that looks like a honda lug and sits the same but is a 21mm is a hyundai (i think)
Old Jul 30, 2008 | 12:15 AM
s2k aok's Avatar
my trunk one seems to fit my rim locks adapter which is 3/4" and if i convert it to metric we get 19mm...
i know this 'cause i swapped back to the stock rims and nuts for the day to enjoy the increased acceleration.
side note: weighed my rear tsw 18" in at 50 lbs (rim/tire) and the stock 16" rears were 42 lbs (rim/tire).
Old Jul 30, 2008 | 12:16 AM
s2k aok's Avatar
Old Jul 30, 2008 | 04:12 AM
TubeDriver's Avatar
Your lugs are not OEM. Which is probably a problem if you have OEM wheels since Honda uses a ball seat and most aftermarket lug nuts use a cone seat. Not safe and you will damage the wheels.
Old Jul 30, 2008 | 11:56 AM
s2k aok's Avatar
yeah, i use my oem lugnuts on my oem rims and my rimlocks on my aftermarket rims. a new set of lugnuts is not expensive at all (well some are $40 a set)...
Old Jul 30, 2008 | 08:47 PM
supahman04's Avatar
no its a honda lug. i think the previous owner swapped them with the oddesy lugs. idk.
Old Jul 31, 2008 | 08:46 AM
TubeDriver's Avatar
Check the lug nut seating area. If it is bulged then they are fine with OEM wheels. If the seating area is a cone shaped you are screwed.
JDM4Life
Oct 11, 2006 07:48 PM
stockae92
May 7, 2006 03:51 PM
philipf22
Mar 30, 2006 12:17 PM
ac09lude
Jun 5, 2005 09:21 PM
William
Apr 10, 2001 01:14 PM
