Chewing through rears fast.
Old Feb 17, 2013 | 08:50 AM
Presto123's Avatar
Default Chewing through rears fast.
I have noticed my car eating up rear tires pretty fast as of late. I had a set of sumi htrz3 that were completely bald after only 6k miles. I got an alignment after and replaced with another set and after about 4k miles they look more than half way worn. I am running about -2 camber in the rear and my toe is pretty close to stock. The car has been lowered on skunk springs for about 3 and a half years but have only been experiencing this problem in the past year. Any ideas?
Old Feb 17, 2013 | 10:32 AM
ZDan's Avatar
What is rear toe *exactly*? Stock AP1 rear toe spec is a very wide range, from 0.33 - 0.67 degrees total. If it's toward the high end, have it reset to the minimum end of the range, or less even. I run 0.2 degrees total. In my experience, going from the maximum end of the range to less than the minimum more than doubled tire life with no ill effects (handling actually became more linear and less twitchy over bumps and traction-challenged surfaces).
Old Feb 17, 2013 | 01:28 PM
Presto123's Avatar
Toe is .4
Old Feb 17, 2013 | 02:58 PM
ZDan's Avatar
Originally Posted by Presto123
Toe is .4
Degrees? Per side or total?
Old Feb 17, 2013 | 03:11 PM
Presto123's Avatar
.4 degrees per side.
I would have posted all the specs but I can't find the sheet anymore.
Old Feb 17, 2013 | 03:24 PM
ZDan's Avatar
0.4 degrees per side is WAY excessive. Have them knock it down to minimum spec: 0.16degrees per side, 0.33 degrees total. Rear tire life will be more than doubled
Old Feb 17, 2013 | 04:31 PM
S2k007's Avatar
Yep rear toe is the culprit.
Old Feb 17, 2013 | 06:00 PM
c32b's Avatar
^ what he said.
Old Feb 18, 2013 | 07:35 AM
Presto123's Avatar
Thanks everyone.
Old Feb 18, 2013 | 12:55 PM
RedCelica's Avatar
holy crap bro...that's A LOT of toe...I run .16 total!
zeroptzero
Mar 27, 2016 07:15 PM
ncaudio
Nov 14, 2013 09:31 PM
AE_Racer
Jul 28, 2013 12:24 PM
JVS2
May 26, 2009 10:02 PM
PilotChris
Feb 4, 2005 01:53 PM
