Correct rolling stock Diameter
Old Sep 5, 2002 | 06:43 PM
Porsche951's Avatar
Default Correct rolling stock Diameter
This is for my wrx, right now I'm running 225/45-17 but intend on geting 18's soon my question is how much wider of a tire can I go to beyond the 225/40-18. The reason I ask is because of C&D wrx which they put 17's w/ 235/40-17 which they said kept the same rolling stock diameter. Please help.
Old Sep 6, 2002 | 03:37 AM
ccarnel's Avatar
look on the oem tire on the tire rack under "specs" when you look under tire. I think one of the fields is diameter. You then can compare to any tire you want
Old Sep 6, 2002 | 04:32 AM
PLYRS 3's Avatar
225/40/18 (25.08 inches dia.) is the closest to 225/45/17 (24.97 inches dia.)...........
255/35/18 (25.02 inches dia.) is the next "widest", yet appropriate, size you should consider.
Old Sep 6, 2002 | 08:01 PM
99civicboy's Avatar
i still got the formula, here we go
for example; 205/55/16
try to do this
( 205 * 55 % * 0.78735 ) + 16
= ( 205 * .55 * 0.78735 ) + 16
= 24.877 is the dia size
Old Sep 8, 2002 | 08:39 PM
RT's Avatar
RT
you can go 285/30-18 if you have the clearance
TrumpetTitan
Aug 1, 2011 12:09 PM
JumpDriver
Apr 18, 2009 07:41 AM
Spec_Ops2087
Nov 8, 2007 05:14 AM
t.vo408
May 10, 2006 04:57 PM
roadents2k
Mar 23, 2006 12:48 PM
