Correct Tire Sizes for Volks
Old Dec 10, 2009 | 05:01 PM
bTone's Avatar
Default Correct Tire Sizes for Volks
I have a set of volk LE37s that I will be putting on my 2002 s2k from my turbo mr2. They are in the need of some new tires.
17x7.5 40 offset
17x8.5 40 offset
I plan on running a 235/40 on the rear. My fronts i will be running a 205 but im not sure the proper aspect ratio to run. 40?45?
But the sizes with the most choices is front 205/45 rear 235/45. Will i be ok to turn those tires sizes on these rims?
The others have very little tires to choose from if i want to match front and rears with same tire.
Any guidance in this situation would be appreciated. And i know there will be possible rubbing on the fronts.
Thanks
Brenton
Quick Pic of the MR2. Bye Bye. Hello S2K
Old Dec 10, 2009 | 11:29 PM
silvs2k's Avatar
I have this exact setup as you and i have 225/45 and 255/40. I'm even running 5mm spacers all around too. I have a simple roll on all four corners and slammed on the ground.
Old Dec 14, 2009 | 08:08 PM
bTone's Avatar
Thanks for the reply! Nice! how much of a drop do you have? Im trying to stay away from having to roll my fenders too much though thats why I chose to go with a smaller tire size. Any pictures?
Old Dec 14, 2009 | 08:24 PM
RickIsYoDaddy's Avatar
thats really small... you could fit oem ap2 sizes, 215/50/17 front 245/40/17.
I currently have 18x7.5 +35 and 18x8.5+35 with 225/40/18 and 255/35/18. Fronts never rub and rears rub on big holes only. Slight fender roll on the rear, no roll on front on OEM suspension.
Old Dec 18, 2009 | 11:25 AM
Jim@tirerack's Avatar
Former Sponsor
I agree. Go with the 215/45R17 and 245/40R17. The sizes you mentioned will change the height of the tires front and rear.
If I can help with the tires let me know.
Old Dec 18, 2009 | 10:22 PM
bTone's Avatar
Thank you both! And Jim I will be ordering the tires from tirerack very soon within the next week. Should I just go through the site? or directly deal with you?
Brenton
Old Dec 19, 2009 | 11:56 AM
Former Sponsor
Either way is fine. Just enter my name as a contact name if you order online.
Thank you again,
GpWaP1 s2k
Apr 7, 2010 02:04 PM
BLanham
May 13, 2008 11:43 AM
Dr Jekyll
Aug 4, 2007 11:01 AM
9kFever
Jan 13, 2005 08:46 AM
fpdok2
Nov 9, 2004 02:39 PM
