Custom Fitted Wheel Setup Question
Old Apr 26, 2006 | 08:57 PM
TrackStarS2K's Avatar
Default Custom Fitted Wheel Setup Question
This is for looks only. Absolutely no track or even hard street driving. OEM's will be used for that. The setup I would like to create is as follows.
17x7 Front +60 offset with center bore 70 possible hubcentric adapter to fit 64? H&R 5mm spacer if needed...
17x7 Rear +60 offset with center bore 70.
Tires front 205/45/17
Tires Rear 225/45/17
Is this at all possible even though it is apparently not the opptimal setup for any s2000 used for any purpose?
Old Apr 27, 2006 | 10:18 AM
Jim@tirerack's Avatar
Former Sponsor
I am sure it will fit but I am not sure why you would want such a narrow wheel and tire on the rear. Also if you are going to do a custom wheel why would you need to run a spacer?
Old Apr 27, 2006 | 10:49 AM
SpitfireS's Avatar
May I ask what aftermarket 17x7 wheels have an offset of +60mm
Or is that the "custom" part?
Old Apr 27, 2006 | 02:49 PM
For OEM look plan is to use 17x7 from DC5 Type-R. They are +60 I really like to keep my car in honda only fashion, and they are my favorite wheels produced for honda.
Old Apr 27, 2006 | 03:00 PM
kayvan_pour's Avatar
Banned
THose wouldnt even look good at all... Those wheels will be sunk so far in the fender it will look terrible!!!!!!
Old Apr 27, 2006 | 08:09 PM
Really? Is the stock offset not +55 up front and +63 in the rear? With a 5mm spacer in the front to compensate for the 5mm difference and of course the DC5 wheel being +60 will actually be pushed to the edge a bit in the rear. I am not understanding how they would not sit almost flush if not a bit over in the rear with this setup?
Old Apr 27, 2006 | 10:23 PM
Banned
Look at the pictue of my car in my sig... I'm running 17x8.5 +35... That is flush... But of course you can always add spacers if you would like.
Old Apr 27, 2006 | 10:34 PM
SpeedxRacer's Avatar
5mm is not a whole lot of difference... its about 1/5th of an inch. It will NOT push it towards the fender.. the stock ap1 wheel is 16x7.5 +65 which means the stock s2000 wheels will still have +12.5mm over your DC5 wheels.
PizzaBoy
Jan 27, 2014 01:27 AM
oyitzpreston
Jun 27, 2009 10:39 PM
otbs2k
Sep 8, 2008 11:08 AM
thewhiteknight
May 21, 2007 08:07 AM
OPTION
Jan 20, 2003 10:07 AM
