Dunlop z1,vs Khumo XS...
Old Aug 14, 2009 | 04:41 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Default Dunlop z1,vs Khumo XS...
...R-11,and Yoko AD-08 are too expensive s...
So,my choice,is between,Z-1(Dunlop),and XS(Kumho)...
Looking for Max dry cornering; don't care about noise,and/or comfort;don't drive my car in the rain,(if caught in a downpour,drive very slowly...)
Prices are about the same...which would you choose ???
Leaning toward the Kumho...
Old Aug 14, 2009 | 04:45 PM
ZDan's Avatar
http://www.tirerack.com/tires/tests/...y.jsp?ttid=118
Old Aug 14, 2009 | 06:40 PM
clitsy's Avatar
The XS have better dry traction and the Dunlop have better all around performance since they have better wet traction. And I believe the dunlop have higher treadwear.
Old Aug 15, 2009 | 12:27 AM
ans2k's Avatar
doesn't a lower treadwear = softer tire = better grip?
Old Aug 15, 2009 | 02:49 AM
ZDan's Avatar
Don't go by the treadwear number. They are definitely NOT an absolute indicator of grip when comparing between manufacturers, or even between different tires from the same manufacturer.
Regarding the XS having "better dry traction", this is only supported in the dry skidpad test, and doesn't translate into a dry slalom, lap time, or stopping distance advantage. What the tests *do* indicate is that the Dunlops have greater wet traction.
Dry slalom time: Dunlop 3.97, Kumho 4.00
Dry lap time: Dunlop 29.05, Kumho 29.05
Dry stopping distance: Dunlop 79.6, Kumho 81.0
Dry cornering g's: Dunlop 0.97, Kumho 1.01
Wet slalom time: Dunlop 4.12, Kumho 4.29
Wet lap time: Dunlop 30.38, Kumho 31.29
Wet braking distance: Dunlop 84.6, Kumho 94.9
Wet cornering g's: Dunlop 0.90, Kumho 0.84
Old Aug 15, 2009 | 05:44 PM
So,does this means,I should go with Dunlop ???
Would they last longer than the XS ???
Old Aug 15, 2009 | 06:05 PM
ans2k's Avatar
i would go with dunlop but i am short on money. and maybe, depends on how you use them.
Old Aug 15, 2009 | 07:11 PM
FISH22's Avatar
I replaced my Star Specs with the XS, and will probably go back to the Star Specs once the XSs are done.
Old Aug 16, 2009 | 12:52 PM
Please explain why;more details...
Old Aug 16, 2009 | 02:13 PM
ans2k's Avatar
xs sucks in rain. even though you wont drive fast in the rain, its more like the day after it rains and you fit standing water. but i have VSA! VSA FTW!!!
woo
Feb 10, 2010 04:21 PM
dubcac
Mar 3, 2008 04:52 PM
IcebergS2000
May 24, 2006 10:29 PM
rwilk
Mar 19, 2005 11:47 AM
LubedKoala
Mar 14, 2005 10:58 AM
