fitment on ssr sp1?
hey whats up everyone im kinda new to the hole offset thing.
i found a kinda killer deel on some ssr sp1 rims they are 17x8 +31 and 17x9 +37. what will i need to hook it up. ps im lowered on mugen coilovers about 2"
I don't think that offset's going to be enough - they'll stick out too far and more than likely rub/foul the arches
For 8" fronts you need about 15mm taking off the inside hub - ET45~
9" rears ideally you need about ET55
It'll depend on how much material there is on the back of the wheels, but I doubt you'd get those to fit safely
31 and 37 will work.. your going to need to flare both fenders, along with roll em and relocate the tabs in the rear. Tire sizes will be tight though, im guessing a 215 in the front and maybe a 245 in the back.. Also, your camber is going to be probably be a few degrees negative in the rear and you will probably need a little bit of negative camber in the front aswell. I wish i woulda ran a more flush offset like that, those will look sweet as hell.
so do you think 800.00 is a good deel on them
http://i15.photobucket.com/albums/a354/Ral...ls/DSCF1827.jpg
