Having Trouble with Size ...AP1
I am trying to pick out new wheels and tires for my AP1 on tirerack, and am having problems getting what I am looking for.
Here is what I think I want/need
Front
OZ Allegerita 17x7.5 +48
Michelin PSS 215/40/17
Rear
OZ Allegerita 17x8.5 +59
Michelin PSS 245/45/17
When I put my car in to tirerack it won't let me do this setup, only 205 up front. Would this not fit ? Tire rack allows this for a 2008 CR
Front
Rear
Tirerack really limits what you can do, even down to the model year as you have seen the difference between the 08 and your AP1. Since you are using an AP1, it wants to use 205/225 tires. Just enter your model year as an AP2 or call them. Your sidewall numbers are reversed, should be 215/45 and 245/40. It should all fit perfectly.
I think the sizes you have listed in the OP are perfectly fine (you've realized to flip the tire series) as long as you're not too low. You might rub a little on the front fender tabs if you push the car hard in a corner.
ottawas2000guy
Jan 31, 2017 03:36 PM
