HELP NOW ASAP!
Old Mar 22, 2005 | 09:34 PM
fpdok2's Avatar
I got mine from Bulletproof, 17x8.5 +55, 225/45/17 fronts and 17x9.5 +68, 255/40/17 without rubbing with 1" drop(Eibach).
Old Mar 22, 2005 | 09:51 PM
SpeedxRacer's Avatar
With 255's you should be at a +62 or up at least with some negative camber in order to run it safely.
Old Mar 23, 2005 | 12:36 AM
B SweepeR B6's Avatar
do you have any side shots or a diff. angle? how do you liek the wheels? and how much did bulletproof charge you for the rims? do they still carry them?
Old Mar 23, 2005 | 07:23 AM
fpdok2's Avatar
Unfortunately, I waited three months. They have to special order it from Japan. But it is worth it. I had a set before with +49(17x8) offset in fronts and it rubbed with 225/45 rubber.
Old Mar 23, 2005 | 10:11 AM
ok FpDOK, i just called tirerack n they said they only see 55's available on the computer but if he can get your part number then he might be able to pick up some higher offsets for me. The only offsets are 49 F and 55 R, what is inyour front and rear again? i called bulletproof n they are not able to get these rims anymore.
Old Mar 23, 2005 | 12:02 PM
fpdok2's Avatar
Old Mar 23, 2005 | 12:06 PM
fpdok2's Avatar
Old Mar 23, 2005 | 04:24 PM
i am soo sorry for being or sounding dumb, but which one of those is the part number?
Old Mar 23, 2005 | 07:04 PM
Batbite's Avatar
I'm glad to see that you didn't just go ahead & order the wheels at 9.5" +55. Would have been too bad to buy something that you would have issues with out of the box.
The +68 shown in the pic above is right on the money.....
Nice SP1 wheels......
Here is another example of offset on a wide wheel:
Old Mar 23, 2005 | 07:55 PM
how can you tell about the offset in person?
