HELP NOW ASAP!
Old Mar 24, 2005 | 07:35 AM
  #21
Batbite's Avatar
Originally Posted by B SweepeR B6,Mar 23 2005, 08:55 PM
how can you tell about the offset in person?
You measure it.............see pice below:
Old Mar 24, 2005 | 08:07 AM
  #22
ciccone376's Avatar
based on my calculations (done using this site: http://gs.tolan-hoechst.com/tirecalc.htm )
the 9.5" +68 has an outboard wheel increase of .881"
a 9.5" +62 has an outboard wheel increase of 1.118" (difference of only 0.237")
a 10" +76 has an outboard wheel increase of .816"
the 9.5" +55 has an outboard wheel increase of 1.393 (difference of 0.512")
Now, if you factor in the TIRE with Wheel outboard increases it would be something like this: (compared to the Stock 225 width tires on 7.5" rim)
9.5" +68 with 255 = .471"
9.5" +62 with 255 = .708"
9.5" +55 with 245 = .788 (similair to the 9.5 +62 with 255)
9.5" +55 with 255 = .983"
10" +76 with 275 = .551" (wasn't sure what width tire BatBite was running).
So you can see above why people recommend running a 245 width tire on a 9.5" wheel with the +55 offset. I've seen poeple running the BBS RGR wheel in 17x8.5 with +55 offset and 245 tire and that is an outboard wheel/tire increase of .7xx" also, as well as the BBS RGR 18x8.5+53 with 255's increase of 1.062".
I'm personally going to be running WORK Meister S1 3-piece in 18x8 +56(F) and 18x9.5 +62
Old Mar 24, 2005 | 10:06 AM
  #23
topcat7111's Avatar
Originally Posted by SpeedxRacer,Mar 22 2005, 10:51 PM
With 255's you should be at a +62 or up at least with some negative camber in order to run it safely.
9.5" wide you want the offset to be at least +62 or up. If was i going to do it all over again. I would go with 18x8 with +56 offset and 18x9 with +68 offset.
Old Mar 24, 2005 | 11:55 AM
  #24
B SweepeR B6's Avatar
hey bro, can you please get me your product number? i called tire rack again n they need that inroder to find me the higher offssets. thanks a lot!
Old Mar 26, 2005 | 07:48 AM
  #25
Batbite's Avatar
Originally Posted by ciccone376,Mar 24 2005, 09:07 AM
(wasn't sure what width tire BatBite was running). later
Chris
285/30/18..........
Old Mar 26, 2005 | 12:27 PM
  #26
stonereds2k's Avatar
Originally Posted by Batbite,Mar 23 2005, 11:04 PM
Here is another example of offset on a wide wheel:
Work 10"........
Old Mar 26, 2005 | 12:43 PM
  #27
fpdok2's Avatar
Go to www.speedstar.co.jp/collection/ssr.html.
It will show you sizes of lip with different offsets for your need!
Old Mar 26, 2005 | 06:55 PM
  #28
i just checked, they only have 15 n 16 n i can't understand the language n i tried the bablefish or whatever it is to translate it n it didn't work.
Veloxitymadog
Dec 10, 2008 01:59 PM
Suzuka_05
May 3, 2006 12:20 PM
B SweepeR B6
Mar 30, 2005 12:53 PM
S2K TX
Oct 9, 2004 05:13 PM
kcdc
Apr 29, 2004 01:52 PM
