Help on tire size!
Old Mar 17, 2015 | 08:42 AM
BokyoS2K's Avatar
Originally Posted by s2000Junky
Originally Posted by BokyoS2K' timestamp='1426607519' post='23543511
got a 17x9 +45 Rpf1 and ready to install .... dont want a fender roll or pulled but want to lower it just enough to make it look good ....
same questions on tire size ....
should i go with
255/40
245/40
234/45
any help would be much appreciated ....
thanks
If you run enough negative camber in the back ie (-2.5 -3) you can get away with that on a 245/40. Lowering the car more then an inch will cause you a problem. And if you got a square set up, you will be in trouble up front. Not going to happen. No way around rolling the fenders on this car if you want the look I know you’re after.
thank you ....
Miahjera04
Oct 31, 2014 06:10 AM
jon o
Aug 27, 2013 03:52 PM
MurphyS2K
May 27, 2012 02:06 PM
RJayRain
20
Jan 22, 2012 12:30 PM
DSMRacer
Jun 11, 2009 04:19 PM
