Help with wheels size
Old Jul 6, 2011 | 09:46 AM
Boricua's Avatar
Default Help with wheels size
Hey guys!
I'm checking out various wheels for my s2k and so far I've seen the set that I want.
They are staggered,
17x8 Front and 18x10 Rear
5x114.3 Bolt Pattern
51+ Offset Front and Rear.
Do you guys think this set will fit my car with no problems?
My car is NOT lower nor has any suspension at all, is bone stock and I want to have it that way.
Any help will be appreciated, thanks!!
Old Jul 6, 2011 | 11:13 AM
Boricua's Avatar
Any help?!
Old Jul 6, 2011 | 07:38 PM
RedCelica's Avatar
you'll have to roll and flare the rears. With the right sized tires you should be fine on the front. Why are you putting 17s on the front and 18s on the rear? It's going to look like a 4-wheeler with 18s btw.
Old Jul 7, 2011 | 05:44 AM
ZDan's Avatar
215/45-17 fronts on 17x8 +51 and 255/35-18 rears on 18x10 +51 shouldn't be a problem at all with no fender work, esp. if you add some negative camber, around -1 front/-2 rear maybe...
Old Jul 7, 2011 | 07:55 AM
RedCelica's Avatar
255/35/18s are made for a 9" rim...not a 10" rim. Just because you can make it fit doesn't mean that you should.
Old Jul 7, 2011 | 09:30 AM
Boricua's Avatar
Like a said before, I really dont want to have any problems down the road. I want to have my car stock as possible.
Old Jul 7, 2011 | 11:43 AM
ZDan's Avatar
Originally Posted by RedCelica
255/35/18s are made of a 9" rim...not a 10" rim. Just because you can make it fit doesn't mean that you should.
Recommended rim width (which is going to be conservative) for a 255/35-18 is 8.5" - 10". Not a problem.
Old Jul 7, 2011 | 07:17 PM
RedCelica's Avatar
^^^Let me rephrase...the optimal sized rim for a 255/35/18 is 9" wide
OP, both your tire selections are at the most aggressive end of the recommendations from the manufacturers. I'm wondering why. Is it just to make the rims fit? Does this frame of mind make logical sense?
if you want it stock as possible...increase your offset by +7-10 in the rear and go with a 17x9" rim.
What rims are you looking at?
Old Jul 7, 2011 | 07:39 PM
Boricua's Avatar
Im looking at a Special Edition Comptech rims made for the nsx.
spyderlink101
May 2, 2014 11:01 AM
Boricua
Jul 6, 2011 09:18 AM
b20teg
Jul 15, 2008 06:36 AM
RuRoUni_SS
Mar 19, 2008 09:33 AM
Moron
Feb 1, 2005 09:08 AM
