High speed wheel balance
Old Dec 11, 2005 | 12:05 PM
jimi's Avatar
Default High speed wheel balance
Wondering if wheel balance is needed for snow tires. Already have weights on for summer tires and, I don't plan on doing any high speed driving till spring change over.
Old Dec 11, 2005 | 08:10 PM
gotswap's Avatar
Not sure what you are asking here? What do weights for your summer tires have to do with your snow tires?
Simple answer is yes winter tires need to be balanced. If they are not it will most likely vibrate and reduce the tire life.
Old Dec 12, 2005 | 08:35 AM
S2kracka's Avatar
An unbalanced tire will wear out more quickly, not ride as nice, be louder, and but extra stress on your suspension components. Balancing is standard at every place I've seen that will mount tires.
Old Dec 12, 2005 | 03:26 PM
NFRS2K3's Avatar
I was thinking about getting my new Winter Tires re-balanced because they seem to get a bit shady starting around 75-80MPH. I was thinking that the shop must not have used a high speed balancer and this is why I am experiencing the slight shimmy at those speeds. The tires I got are V-Rated so I'm sure that doing 80+ shouldn't be an issue with the proper alignment. I believe a V rating is good up to 149MPH...
Old Dec 12, 2005 | 04:24 PM
jimi's Avatar
I'm sold. Thanks All. They feel great, A lot softer. Since I had worn SO3's, Can't wait for Snow! BTW running Blizzaks LM-25F LM22R
flythecoupe
Aug 3, 2013 11:59 PM
porschedave
Apr 10, 2008 08:20 PM
zeiss
Mar 10, 2007 03:05 AM
TookayS2K
Oct 16, 2006 02:32 AM
simons2k
Jul 17, 2003 12:33 AM
