how much modification? wheel noob sorry
Old Feb 20, 2014 | 02:25 PM
squared S2k's Avatar
Default how much modification? wheel noob sorry
Hey guys.
Basicly how much modification would I need to do to fit 17x7.5 +35 rims??? On eibach springs ..plan on running 2115/45/17 tires.
I found the wheels I want :-) .....my problem is fitment :-( ... The wheels are only available in 17x7.5 +35. I know it's a low offset and won't fit on the stock body... From what ive learned the lowest I can go is +45 so I'm hoping I can fit these with a little camber. I plan on running bridgstine potenza re11a 115/45/17. Don't want too much camber because I want to stay functional and don't want to ruin these tires..... I'm dropped on eibach springs......would rather avoid rolling my fenders......and is that a good functional tire size?? The wheels would be squared...
Should I just find a diffrent rim witha higher offset and are stagard??
Thanx for all your help guys .
Old Feb 20, 2014 | 02:32 PM
Manga_Spawn's Avatar
Site Moderator
#1 Its modification not modificatin.
#2 Those wheels are to narrow for the rear. If you are buying 17's you need to at the very least match AP2 oem width which is 7 inches wide front and 8.5 rear. This allows you to run proper sized tires.
#3 Those will fit the rear with a roll and tab relo. The front will be close but would fit with a roll and some camber.
Conclusion is don't waste your money. They are to narrow and will look odd on the car and not perform very well.
Old Feb 20, 2014 | 03:39 PM
Thanks for the reply man.
I didn't notice I misspelled it ..English isn't my subject so ima misspell more words hope you guys can forgive me ;-) lol ........but ok not the answer I wanted but the one I expected. I will start looking at other wheels. I Haven't looked at mixing wheel sizes ... Whats your oppinion on running 17x7.5 +35 up front and 18x8 +45 in the rear?? ..would that look odd?? And would it still require the same modification??? Thanks again for all the help.
Old Feb 20, 2014 | 03:48 PM
1nate7's Avatar
With no fender work and the car lowered, you need to be looking at offsets +55 or higher in 8"/9" widths - not easy to find. I'd suggest looking at Tirerack, they only list conservative fitments so you know just about everything they carry will fit without a fender roll.
Old Feb 20, 2014 | 05:52 PM
Site Moderator
And even then if you lower you will likely need to roll the front fenders. Also no worries in the misspelling it was actually a funny way to misspell it. Again the oem ap2 wheels are 8.5 for the rear. If you don't have at least that you can't run a 245 correctly and that's what you want. With wheels you want the looks but you also want better grip and performance as well.
Old Feb 20, 2014 | 07:26 PM
Ok cool that answers my queistions :-) ... Unfortunately some dumb ass backed into my car >=[ ...thought I had the plates but I'm missing a number.. So I'm stuck with the repairs ......Might have to put the wheels on hold till I fix the car :-( ....on a positive note the hood is already rolled so I might as well roll the fenders ;-) haha .... All jokes aside. Thanks again guys for all the help
Old Feb 20, 2014 | 10:15 PM
IrishCarBomb's Avatar
damn.
Old Feb 21, 2014 | 08:05 AM
Site Moderator
Do yourself a favor and spend some time reading the forums and learning more about the car. Also if you need wheels that bad find your local subforum and see if someone has a set of OEM ap2 wheels. Can't go wrong with those and you can always sell them when you find aftermarket wheels that fit what you need.
sho-one
Sep 2, 2018 10:22 AM
PizzaBoy
Jan 27, 2014 01:27 AM
Honda_4life_
Dec 30, 2013 08:40 PM
gdub
Dec 10, 2009 12:18 PM
otbs2k
Sep 8, 2008 11:08 AM
