Hub ring
Old May 16, 2008 | 01:44 PM
Defjux's Avatar
Thumbs up Hub ring
Hi, I am getting a set of Work Emotion Forged. Seems hub rings are not coming with the wheels, and I know I do not necessarily need hub rings to fit the wheels on the car, but would like to get some just to be on the safe side.
I don't have the wheels spec, any of you know what hub ring size I should get?
Old May 16, 2008 | 03:49 PM
1nate7's Avatar
You need 2 different sizes. The hub bore is 70.7mm front and 64.1mm rear. Those will be the inside diameter of the hubcentric ring. The outside diameter of the ring will be whatever the wheel bore is, probably around 73mm.
Old May 16, 2008 | 03:58 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
You know your stuff.
One of mine is broken(CE-28 N).
Where can I get a new one ???
Old May 16, 2008 | 04:11 PM
1nate7's Avatar
Jim at Tirerack or one of the forum vendors can probably get one for you. If you know the size you need you can try a local tire store. I picked up a set at a local Discount Tire.
Old May 16, 2008 | 04:41 PM
Defjux's Avatar
Thanks, I now need to figure out the wheel spec (wheel bore).
MY00S2000
Jan 31, 2016 12:51 PM
Vtakanonymous
Sep 9, 2012 07:18 PM
nglaser
Dec 10, 2010 03:29 PM
surrey honda
Mar 9, 2006 01:06 AM
eraxpres
Jan 24, 2006 11:41 AM
