Hypothetical question
Old Jun 7, 2008 | 06:27 AM
iamhomin's Avatar
Default Hypothetical question
What would happen if I were to put 255/45/18 and run 255/35/18 in the front. Would running the same width in front and rear cause some steering issues?
TIA.
Old Jun 9, 2008 | 07:31 AM
Jim@tirerack's Avatar
Former Sponsor
Without modification to the suspension running the same width tires on all four corners would not improve handling. Also the tires you mention would be a lot taller tire in the front than the rear which is not a good idea.
Old Jun 10, 2008 | 07:59 AM
Nine's Avatar
uh jim the stock tires are taller in front than the rear? Are you sure you're not making a broad swooping generalization that specifically may not be true for RWD cars?
Old Jun 10, 2008 | 11:48 AM
Former Sponsor
No the stock tires are not taller than the rear. The rear tires are wider not taller. The tires he mention would be 27" tall for the 255/45R18 and 25" tall for the 255/35R18. There is no way they fit on any car together. I was making a generalization for the handling on a S2000. If he were talking about a BMW then it is a different story.
Old Jun 10, 2008 | 12:33 PM
spa01s2k's Avatar
He says 255/35/18 in the front. Not the other way around.
Ghent
Jan 23, 2013 07:09 AM
REVHIR
Sep 12, 2009 05:31 PM
hamlet9634
Dec 4, 2008 07:44 AM
Brutewes
Mar 22, 2004 11:40 AM
bazaar
Oct 16, 2002 03:07 AM
