Jim, please help! 17" asa ar1
Old Oct 8, 2004 | 11:04 AM
djbrkb's Avatar
Default Jim, please help! 17" asa ar1
hey jim,
i like the look (and price) of the asa ar1 for my s2000.
your site recommends 205-45-17 and 225-40-17.. (offsets front 48 and rear 45)
i figure this is either a mistake or they will rub with wider tires. please confirm.
i would like at least to go the stock '04 sizes 215-45 and 245-40...
can i without rubbing????
I also plan to go with h&r oem sport springs .75" and .6" drop at a later date.
will this setup rub????
in addition, i would prefer these rims in hyper silver finish but they are not avail..
i found a place in santa ana, ca (www.wheel-repairs.com) that will strip and re-powder coat in hyper silver for $110 ea.
does anyone at tirerack know of anyone who does hyper silver finishing? (preferably in michigan)
look forward to your response... thanks for the time..
david
Old Oct 9, 2004 | 11:44 AM
Jim@tirerack's Avatar
Former Sponsor
I actually would recommend the 215/45R17 and 245/40R17 front and rear. I would not recommend powder coating the wheels. You have to be very careful when powder coating wheels. Too much heat and the wheels will become soft. The wheels come with a stainless steel lip that would not powder coat as easily.
Old Oct 13, 2004 | 09:45 AM
bills2k_2001's Avatar
Just got these wheels and tires from tirerack. This is what was recommended. A rep did call and tell me the back would stick out a little in the back. Haven't had a chance to drive them much, but they don't rub. Good luck.
205/50WR-17 Bridgestone Potenza RE750
2 225/45WR-17 Bridgestone Potenza RE750
Old Oct 13, 2004 | 10:25 AM
djbrkb's Avatar
thanks for the pics.
jim, can you confirm 215/45 and 245/40 setup rubbing (also if i add h&r sport springs (.75" f & .6" r))?????????????????????
Old Oct 13, 2004 | 08:22 PM
Nobody's Avatar
225s on the rear? HA! The S2000 oversteers enough with the stock 225s (that are actually 245s). But put 225s on the back? That's a good recipe for some serious oversteer. At least you know if you ever have an accident that you can blame TireRack for recommending the wrong sized tire. Jim gets it right, but for some reason TireRack places more emphasis on the 225 rubber stamp on the side of S02s than the actual width of the S02s.
Old Oct 14, 2004 | 04:17 AM
djbrkb's Avatar
nobody,
you might be right here... i just checked wheel & tire fitment
for a 2004 on tirerack and the same rims are available but
they recommend the wider 215/45 and 245/40's... i don't believe there
were any suspension or wheel spacing changes from 2000-2004.
right? so the wider tire sizes should be ok on a model year 2000...??? what do you guys think?
david
Old Oct 14, 2004 | 10:49 AM
Former Sponsor
The web site is what you are referring to. It goes off of OE tires and can't think about the S02 tire being wider than other tires. Call me and I can help. I recommend the 215/45R17 and 245/40R17 on the car. Like I said before the performance is a little better this way with a better front to rear stagger.
There is nothing wrong with the 205/50R17 and 225/45R17 on the car but the other size will perform better. Not everybody is looking for the best handling though. Some people just want the look and don't drive the car hard.
If I can help just call me.
Old Apr 4, 2005 | 07:02 PM
[QUOTE=Nobody,Oct 13 2004, 10:22 PM]225s on the rear?
Old Apr 5, 2005 | 06:56 AM
aggie's Avatar
I would bite the bullet and put 245's on the rear. There is a pretty good used tire market on ebay for your almost new 225's.
blanka98
Oct 12, 2005 06:22 AM
doodlebug
Sep 9, 2004 12:48 PM
Brownergy
Jan 29, 2004 07:34 AM
Grazhoppa
Nov 23, 2003 09:45 PM
brandonb
Jun 28, 2001 10:42 AM
