Lots of negative camber?
Old Sep 4, 2007 | 08:27 PM
B.Money's Avatar
Default Lots of negative camber?
Hey guys, you may remember I posted up a question a little while ago about getting an alignment done after new wheels/tires. Anyway I called up West End Alignment and darren assured me there is no need for an alignment.
Anyway, now that I have my new wheels/tires on. It looks like I have loads of negative camber. I never noticed (or probably even looked) at what it was before, but now looking from the rear I can see the tops of the tires facing inward.
Is it normal to have a semi or very semi aggressive alignment with enough negative camber where its actually noticeable??
If pics are needed let me know! TIA
Old Sep 4, 2007 | 10:16 PM
Jrz's Avatar
Jrz
New wheels shouldn't have anything to do with you alignment unless it was that way before you touched it. But, if you messed with the suspension like changed out springs, you will need an alignment. You should see some negative camber in the rear as it is designed that way for better handling. If it's more than you think is necessary, you should get it checked by a good shop.
Old Sep 4, 2007 | 10:38 PM
B.Money's Avatar
hmm, maybe ill take a pic for good measure either way. Maybe I even have one already on here, not sure.
I didnt play with the suspension at all. Havent touched it. Just seems like more than I remember but is all good. Ill see how it feels once my tires are broken in
Old Sep 6, 2007 | 01:10 PM
neveronlines2k's Avatar
I think it has to do with the face of the wheels. It makes it more noticeable. I have a bunch of Camber too and you can notice it by looking at the wheels.
Darren does alignments with negative camber and adds some toe to keep the wear down (at keast thats how he explained it to me)
Old Sep 6, 2007 | 01:31 PM
B.Money's Avatar
Ah i see. Ill have to look behind your car at homecoming and compare or somethin.
Old Sep 6, 2007 | 01:43 PM
For sure , I would think they should be about the same though my alignment has been re-done and I will have to see Darren again soon
a2l90e
Jun 5, 2014 04:46 PM
toniotran
Jan 7, 2013 12:52 PM
TJF
Jul 21, 2006 09:58 AM
hylysly
May 25, 2006 09:10 AM
JT-KGY
Nov 10, 2003 02:59 AM
