my car it's steering around while driving
i got Bridge stone RE-01R on with 32 PSI all around, but the car steers most likely to the right everytime i drive throught some uneven street roads, also when i stop in front of the stop light , i usually turn my gear to the N then brake , about while i am braking slowly , the steering wheels turns to the right.
i have check everthing, i brought my car to a friends shop and did an aligment for all 4 wheels, and it happens too, and i also bring my car to the dealer , they did all 4 wheels aligment agian too, and same problem.
So does anyone had any samuler issues like i do b4?
If so please let me know ASAP .
thx
Leo
thx
Leo
probably the tires. It has to do with the lines (if the RE01R's have them)
This is only part of it. I can't find the three lines on the tread explanation
[URL=http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=12
yes the wheels are been balanced , and the tires are all going the at the right position.
but i was thinking if thier is problem with the rims??
or maybe the cams or casters?
because i remmeber i hit a big huge curb with the 2 wheels on the right side, i was doing about 35 ~40 mhp, but that was with the stock rim and tires.
the funny thing is it does totally fine on a nice straight road.
Steering Tie-rods aren't horizontal and therefore more sensitive to the bumps on a bad tarmac.
To be more precise the steering angle varies with regards to the amount of damper stroke.
Hope this helps.
Regards,
Nico.
Originally Posted by Sinco06,Dec 17 2007, 12:44 PM
Hi, is your car lowered ? This could be an explanation as lowering modify the steering geometry as follow:
Hope this helps.
Regards,
Nico.
Hope this helps.
Regards,
Nico.
is thier any possible issue for the rims???
thx
Originally Posted by leo520,Dec 17 2007, 08:21 PM
sorry for my languege i didn't really understand everything.
thx
thx
thx
thx
Your problem is not linked to your rims if this is your only worry.
Cheers and Merry Xmas.
Because you disengage the drivetrain while braking (by shifting to neutral), and you're pulling to the right, you have one or more of the following going on:
Your right rear brake is adjusted tighter than your left rear brake;
Your left front brake is working, but your right front brake isn't. That you can stop at all has to do with the diagonal pr0portioning valve.
Your left and right tire pressures aren't matched.
Sounds like you could also have bent your suspension mounting points when you crashed into the curb. The alignments should have picked that up, but there's the chance that static alignment is within limits, but dynamic alignment is affected by a bent component.
Good luck
Good luck
Bubbels**
Jul 17, 2017 12:27 AM
