Need help ASAP!
Old Apr 24, 2009 | 01:53 PM
J-rod's Avatar
Default Need help ASAP!
Ok . . . so here's the situation
I just took off my volks and put my stock ap1 rims back on . . . however, there are hubcentric rings still on the fronts, I couldn't get them off, was able to get the rears off though . . . so do I absolutely have to remove the hub rings, or will the car be safe with them still on under the stockers . . . and no, the stockers are not sitting flush with the hub, there is a small gap inbetween the wheels and the hub
Thanks in advance!
Old Apr 24, 2009 | 02:59 PM
SpeedxRacer's Avatar
remove, use a screw driver and pry em out after letting em soak in wd40 or something.
Old Apr 25, 2009 | 11:58 AM
Jim@tirerack's Avatar
Former Sponsor
You do have to get them off. The wheels are not going to go all the way on if you don't and they can come off if the bolts loosen.
Old Apr 25, 2009 | 09:14 PM
J-rod's Avatar
I got them off this morning . . . took a screwdriver and hammer, and hit against the inside of the hub ring that was slightly extended past the rim of the hub . . . took about 2 minutes a piece to get them loose, then pry them off
thanks for the info!
Craig.h
Feb 9, 2014 01:16 AM
fusionchickenleg
Oct 7, 2008 03:50 PM
phizzak.s2k
Jun 17, 2008 02:09 PM
xdavieexx
May 1, 2008 11:17 PM
bkw
Apr 23, 2002 01:31 PM
