Need a Little help with width and offset
Old Aug 17, 2005 | 08:34 PM
CarBoN's Avatar
Default Need a Little help with width and offset
iv been doing a little searching, and i kinda understand offsets and widths
but i still have a few questions
first 17x7.5 +45 all around, bad idea? downsides? should you run a spacer in the rear? if so how much? and what are the recomended tire sizes?
then mainly what are the handling downsides or affects from running non staggered width rims, but with staggered tire size
thanks for any and all info
i did some searchin but didnt find quite what i was looking for
thanks again
Old Aug 17, 2005 | 09:15 PM
xviper's Avatar
Originally Posted by CarBoN,Aug 17 2005, 09:34 PM
+45 all around, should you run a spacer in the rear? if so how much?
You seem to not understand what a spacer does. You are talking about +45mm offset. You need MORE offset. A spacer would DECREASE this. For example, if you put on a 10mm thick spacer, your offset would be like +35.
Old Aug 17, 2005 | 09:45 PM
CarBoN's Avatar
no i understand them, i just thought they might need to stick out further in the rear, so +45 is ok in the rear?
how bout the front?
Old Aug 17, 2005 | 09:50 PM
xviper's Avatar
how bout the front?
Well, consider that stock is +65, I think you get the idea.
Old Aug 17, 2005 | 10:01 PM
Kel's Avatar
Kel
Stock size is F16x6.5 +55 R16x7.5 +65. Offset is measured in mm.
Old Aug 18, 2005 | 05:37 AM
Ubetit's Avatar
+45 is already going to:
1. Stick out
2. Rub, even at stock height.
Old Aug 18, 2005 | 10:13 AM
spa-zz's Avatar
1. Stick out
No it won't, because it's only 7.5" wide. People run 8" wide wheels with 40 offsets and get away with it at stock height.
Old Aug 18, 2005 | 10:47 AM
xviper's Avatar
If you're rolling down a "smooth as glass" motoring environment, then no, it won't rub. However, even with the proper offsets (+53), 17" X 8" rim and 225 tires on the front, upon severe suspension compression, the top plastic fastener holding the wheel well splash shield will get ground down. With +40, it will do the same thing during hard right handers up a slight incline. Have those "people" check that fastener.
Old Aug 18, 2005 | 11:31 AM
spa-zz's Avatar
This is assuming everyone has the same tires and same camber settings, which they don't. This is why some people have problems and some don't. It's not an exact science, unfortunately.
Old Aug 19, 2005 | 12:18 AM
RT's Avatar
RT
.......... actually, it is
