Need a Little help with width and offset
using the calculator on the faq link above, 245 tires with 35mm offset give a result of 6.7...225's give a 6.3. The stock 205's with 55mm also give a 6.7...
I have no idea what the hell these numbers are, but if the first one and the last one match, they must be the same, right?
Obviously the fronts are sticking out significantly wider than stock in the picture, but I'm curious if those are 8" rims on the front, or if they're 7's.... If they're 7's, then there's pretty much no way I can put on the rims I want. Why'd Honda have to make this so damn difficult??
Well they (wheels boutique)screw it up again.
Not only did they send the wrong offset again they also put the wrong tire on the rim. There is no way a 19x8.5 +35 with a 235 is going to fit on the front. This is what it should have been 19x8.5 +45 with 225 which barley fits; did a test fit with another rim/tire combo with the same parameters.
So my suggestion do not buy anything from wheels boutique out of Mami!!!!!!!!!!
The front's going to stick out just like the above pics. If that's the look you want, then go for it.
The rears will stick out 3mm further than the above pics. I dunno, I don't think I'd try it.
thread title says "a Little help"
