Non Staggered Setups
Old May 12, 2011 | 08:57 AM
Suzukaboy's Avatar
Default Non Staggered Setups
I notice people ask questions about various non staggered setups. Besides the mechanical rubbing questions I am wondering what these setups do to handling. Even with the staggered setup the AP!'s had a rep of being tail happy. I've driven a staggered setup (StarSpec 225 255) on my AP2 and I don't consider it tail happy but it doesn't exhibit noticeable understeer either. It seems to me a staggerd setup would create oversteer on my car from what I consider to be neutral handling. My experience is all street.
Old May 12, 2011 | 10:19 AM
Jim@tirerack's Avatar
Former Sponsor
I would say that if you are not changing the suspension I would stay with the staggered set up. The car will be even more tail happy with the same tire size all the way around. The staggered, wider tires on the rear help keep the back of the car in check. If you go with a larger anti roll bar and it is more of a racing application the same size all around works well.
Old May 12, 2011 | 11:34 AM
deepbluejh's Avatar
Stay with the staggered setup.
Old May 12, 2011 | 11:36 AM
thanasis11's Avatar
im non staggered with stock suspension and i love it. the car is really tossable
Old May 13, 2011 | 04:39 AM
scareyourpassenger's Avatar
This tell me you have yet to push your car to the limits.
The s2000 is great handling car with little room for improvement. Most of the advantages of going to non staggered is tire rotation and equalizing out adding a larger front sway bar. a larger front bar improves rear stability a bit.
Old May 13, 2011 | 08:06 AM
thanasis11's Avatar
i have pushed it to the limit and exceeded it a couple of times by accident, and i like it. i have noticed the roll and more bumpsteer probably due to more roll thus greater deflection so im waiting to install my new coilovers with higher front spring rates which effectively is the same as stiffer front roll bar.
Old May 13, 2011 | 01:51 PM
spdracerut's Avatar
Read this series:
http://www.motoiq.com/projects/project_honda_s2000.aspx
Old May 14, 2011 | 10:02 AM
acus2k's Avatar
^Thanks for that link! That is an awesome resource. I'm actually going non staggered soon and had no idea that it could HELP to remove the rear sway. Thanks
navycorpsman27
Apr 23, 2013 06:43 AM
hyoseke
Apr 4, 2010 10:01 AM
CarBoN
Oct 7, 2009 10:23 AM
dukeykun
Jan 1, 2008 04:59 AM
ericshun
May 4, 2007 07:08 AM
