Non-Staggered tire size
Old Oct 6, 2009 | 02:17 PM
Globe182jp's Avatar
Default Non-Staggered tire size
For the next year or so I will be running 4 AP1 rears and its time to get new tires. I will be looking at running 245 all around.
These will be my first time on an S2k with non-staggered set up and I will be trying to learn it while I save my funds up for a 17-9.5 set up with front and rear fenders ect...
wide body set up cost sooo much,
or I may discover I hate it an stick with a traditional set up.
My question is since the Profile of the stock tires is different what should i stick with the front stock 55 or the stock rear 50 ?
Though a quick search shows no one making an 245/55/16 on tirerack, but I still wonder why there is a difference between front and rear profiles?
And last without bringing out the war of proper AP1 rear replacement tires size would 225 be a better choice?
Car is stock for the time being.
Jake
Old Oct 6, 2009 | 03:19 PM
ZDan's Avatar
You need to do your homework on what the numbers in a tire size actually MEAN! A 245/55-16 would be WAY too tall!
225/50-16 all around will be your best bet.
245/45-16 would be a great option but for the fact that the best street tires are not available in this size.
BTW, it's NON-staggered, not "none staggered"!
Old Oct 6, 2009 | 04:05 PM
Globe182jp's Avatar
Thanks for the correction, I never knew a stock 205/55-16 front tire and 245/55-16 would have a difference in height, thanks
Jake
Old Oct 6, 2009 | 04:17 PM
ZDan's Avatar
Yup. The "50", or "55", or "45" represent sidewall height as a percentage of tread width.
So a 205/55-16 has nearly exactly the same sidewall height as a 225/50-16
205*.55 = 112.75mm
225*.50 = 112.5mm
So tire diameter is the same (~24.8")
A 245/55-16 would have a sidewall height of 134.75mm, +22mm taller sidewall, +44mm (1 3/4") larger-diameter tire!
Old Oct 6, 2009 | 04:21 PM
Globe182jp's Avatar
Well that explains everything thanks again
Jake
mason.whitlow14
Jan 3, 2014 06:14 AM
Insert Name
Mar 7, 2010 08:17 AM
dsthez
Oct 26, 2009 12:18 PM
tlee1234
Jan 14, 2009 05:54 PM
User 32625
Aug 19, 2006 05:18 PM
