offset question
i am looking to buy some Rota DPT the specs are as followed
(5x100/114.3/e42/73)
Wheel Diameter (Inches) - 17"
Wheel Width (Inches) - 9"
PCD Bolt Pattern - 5x100 & 5x114 (dual drill)
Offset - 42mm
Hub Bore - 73mm
will they fit on a stock s2000 without having to do any modifying
Offset - 42mm
Hub Bore - 73mm
what tire size would u recommend i was thinking of just using the factory tire specs? also dose any1 know a good shop in the central vally or nearby that can get these wheels to fit right?
I have 8.5" with et42 and I needed a roll, bumper tab relocation and bumper cut. No flare needed. I'm running 245 rear tyres.
the half inch of wider wheel will not make enough of a difference to rub with -2 degrees camber (UK alignment specs).
At 1/1.5 inch drop, there should be no problem, I think I'm at 2/2.5" somewhere.
no decent ones... need to do a decent photoshoot without oversaturating the pics
This one before camber was dialed in, I just turned the rods to max negative camber in the rear (the toe links, so massive toe-out as well)
